I am try to simulate a system containing a linear rod (bond angle = 0).
Even if I use very high bonding/angle energy, the structure collapses or bond angle goes to over 20 degrees.
e.g.,
bond_style harmonic
bond_coeff 1 300.0 0.0
angle_style harmonic
angle_coeff 1 300.0 0.0
Could anyone help me ?
How can I maintain the linear structure of rod?
Thank you.
Isn't a linear rod an angle of 180?
Also, you can do this w/out an angle potential
if you put a psuedo-bond between the 1-3 atoms
with an equil distance of 2*bondlength.
Thank you.
But it still happens when I try with either angle of 180 or pseudo-bond.
Thank you.
you input quote was listing a bond length of 0.
how shall that work at all???
That was an example.
Actual values I used are:
bond_style harmonic
bond_coeff 1 300.0 1.0
angle_coeff 1 300.0 180.0
When I tried with pseudo bond (style #2),
bond_style harmonic
bond_style harmonic
bond_coeff 2 300.0 2.0
Thank you.
if you post a stupid example, you get a stupid answer.
...and they are all useless without being able
to _reproduce_ what you are seeing.
if something doesn't work there are three possible explanations:
- there is something wrong with your input
- it cannot work, because your expectations or your model are wrong
- there is something wrong with lammps
without having the necessary context it is impossible to
know what is causing you problems unless you are a psychic.
