Hi Everyone,
I am trying to use the dump custom/vtk command. I built the vtk code from https://github.com/Kitware/VTK and pointed to the shared libraries generated by it. Below is the contents of Makefile.lammps in /lammps/lib/vtk/ :
vtk_SYSINC = -I/usr/local/include/vtk-7.1
vtk_SYSLIB = -lvtkCommonCore-7.1 -lvtkIOCore-7.1 -lvtkIOXML-7.1 -lvtkIOLegacy-7.1 -lvtkCommonDataModel-7.1
vtk_SYSPATH = -L/usr/local/lib
The code compiles fine, but during linking, I get the following error:
dump_custom_vtk.o: In function vtkSmartPointer<vtkXMLPPolyDataWriter>::New()': /usr/local/include/vtk-7.1/vtkSmartPointer.h:137: undefined reference to
vtkXMLPPolyDataWriter::New()’
dump_custom_vtk.o: In function vtkSmartPointer<vtkXMLPUnstructuredGridWriter>::New()': /usr/local/include/vtk-7.1/vtkSmartPointer.h:137: undefined reference to
vtkXMLPUnstructuredGridWriter::New()’
Anybody faced this issue?
Thank you,
Stephen Thomas.
Hi Everyone,
`vtkSmartPointer<vtkXMLPPolyDataWriter>::New()':
`vtkXMLPPolyDataWriter::New()'
`vtkSmartPointer<vtkXMLPUnstructuredGridWriter>::New()':
`vtkXMLPUnstructuredGridWriter::New()'
please check the VTK documentation. as you can see from the examples
in lib/vtk, LAMMPS has only been tested against VTK 5.x and 6.x, so
most likely VTK 7.x requires additional libraries to be linked against
and this is usually mentioned in the documentation.
Hi Dr. Kohlmeyer,
Thanks for the response. I tried to build and use VTK 6.3 instead. But, unfortunately, I get the same error. I might be missing something else here. Here is the last part of the lammps build output .
mpicxx -g -O -L…/…/lib/vtk -L…/…/lib/atc -L/home/sthomas/projects/VTK-build/lib pair_lj_long_dipole_long.o … -lvtkCommonCore-6.3 -lvtkIOCore-6.3 -lvtkIOXML-6.3 -lvtkIOLegacy-6.3 -lvtkCommonDataModel-6.3 -lblas -llapack -o …/lmp_mpi
dump_custom_vtk.o: In function vtkSmartPointer<vtkXMLPPolyDataWriter>::New()': /usr/local/include/vtk-6.3/vtkSmartPointer.h:117: undefined reference to
dump_custom_vtk.o: In function vtkSmartPointer<vtkXMLPUnstructuredGridWriter>::New()': /usr/local/include/vtk-6.3/vtkSmartPointer.h:117: undefined reference to
collect2: error: ld returned 1 exit status
Makefile:89: recipe for target ‘…/lmp_mpi’ failed
make[1]: *** […/lmp_mpi] Error 1
And here is the Makefile.lammps
vtk_SYSINC = -I/usr/local/include/vtk-6.3/
vtk_SYSLIB = -lvtkCommonCore-6.3 -lvtkIOCore-6.3 -lvtkIOXML-6.3 -lvtkIOLegacy-6.3 -lvtkCommonDataModel-6.3
vtk_SYSPATH = -L/home/sthomas/projects/VTK-build/lib
Thank you,
Stephen Thomas.
Hi Dr. Kohlmeyer,
mpicxx -g -O -L../../lib/vtk -L../../lib/atc
.......................................... -lvtkCommonCore-6.3
-lblas -llapack -o ../lmp_mpi
Makefile:89: recipe for target '../lmp_mpi' failed
make[1]: *** [../lmp_mpi] Error 1
at any rate, the answer to this has to be in the VTK documentation, as
this isn't really a LAMMPS problem. LAMMPS only makes use of a very
small subset of VTK.
apparently, the correct list of libraries depends on how you have
configured/compiled VTK and seems to be changing significantly between
versions.
we have made tests with several linux distributions using the
distribution provided VTK development package and those are the
examples in the lib/vtk folder.
