Dear Lammps User,
I have been working on liquid water sheared between 2 FCC walls in 3D dimensions. Our objective is to obtain the velocity profiles to calculate the slip. Thus, we use only NVT ensemble for our system. Wall-fluid interaction strength ratio is 2.5 . Firstly, velocity of 0.79 A/ps was set up to walls; Maxwell_Boltzmann velocity distributions at 300K, NVT and Nose-Hoover thermostat (300K) were applied for all molecules in 1ns. Secondly, velocity of 0.79 A/ps is still set up to walls to keep them moving, NVT and Nose-Hoover (300K) were applied to all molecules in next 3ns. Results were averaged in last 2ns. However, our results revealed that the velocity of the wall and liquid molecule near the walls reach ~2.5 A/ps. Anyone could support us for this problem? Thank you very much
Best Regards,
Truong Vo
