I’m new to GULP. I’m trying to do something simple with a truncated and shifted LJ potential, but I only seem to get raw truncation. My understanding is that adding “energy” or “ener” to the “lennard” option should result in the truncated and shifted potential, i.e.,
lennard epsilon zero energy
(Full example input file pasted below. When I generate a binding curve, there’s clearly a jump at r = 5 Angdtrom.) I cannot figure out how to get the expected behavior. Any advice greatly appreciated.
Best wishes,
Input file:
single
title
lj binding curve file
end
cell
20.0 20.0 20.0 90.000000 90.000000 90.0
cartesian
Al core 0.000000 0.000000 -1.50
Al core 0.000000 0.000000 1.50
library Al.lib
Library file:
species
Al core 0.0
Al core Al core 1.0 2.0 0.0 5.0
Hi Steve,
I’ve just had a quick try with essentially your input file and I see the energy go to zero at 5.0 Angstroms as expected. Can you confirm that you are using the latest version of GULP 6.0?
Regards,
Julian
OK, I was using GULP 5.1 (and working from that manual). I played around with GULP a couple of years ago but the project got put on the back burner, and simply used the code I’d already downloaded. I guess I wasn’t expecting much to have changed wrt LJ and point charges!
Hi Steve,
Apologies for that - there was a bug at one stage that crept in and it seems you hit it with your old version. Glad to hear that updating the code fixes things.
Julian
