I have a problem loading trajectory file with Load trajectory modifier. Particle id 610 from topology dataset not found in trajectory dataset. The following is my trajectory file and data file format.Please help me.
The files samples you provide seem to be a mix between data and dump files from LAMMPS, but they are not the complete files and you do not say which one you are loading in Ovito. Without that it is nearly impossible to give a proper answer to your problem.
