I’ve read many of the threads about empty log files, but my problem is a little different. I am trying to save log files with a different name so that I have different log files for each run. (I do have the thermo_modify flush yes command also.) However, none of my non-default log files seem to save any data. For example, when I used this command:
log log.equil2000 append
the log.equil2000 file is created, but the only line that is inside this log is “Total wall time.” Meanwhile, a log.lammps file is also saved for some reason, and this file has the details. However, I don’t want this file to hold my thermo outputs; I want the custom named file to have the thermo outputs. Does anyone know what is causing this issue?
Thank you!
Helen Yao
two core pieces of information are missing here:
- which LAMMPS version exactly are you using and on which platform
- please provide a simple example input (e.g. a modification of the
melt example) and the specific command line that you are using to run
LAMMPS
without that, people have to revert to wild guesses.
I solved the problem--I didn't have the log command in the right place. Thank you!
