Logic of calculation of strain
Dear LAMMPS users,
I am calculating the strain value during compression of a single crystal. I have come across the following code:
compute 1 all stress/atom NULL
compute 2 all reduce sum c_1[1] c_1[2] c_1[3]
variable stress equal ((c_2[2])/(3*vol))
variable tmp equal ly
variable lo equal ${tmp}
variable strain equal (ly-v_lo)/v_lo
fix 5 all deform 1 y erate -0.001 units box
In this, “ly” is assigned to “tmp” --> then “tmp” is printed and assigned to “lo”.
With this, engineering strain is calculated in y-axis as erate is applied in y-axis.
I want to know when “ly” is changed after some timesteps, will “lo” changes…???
I want to know the logic behind the calculation of strain.
Dear LAMMPS users,
In this, "ly" is assigned to "tmp" --> then "tmp" is printed and assigned to
"lo".
y-axis.
I want to know when "ly" is changed after some timesteps, will "lo"
changes..???
no. it cannot change because you are using an _immediate_ expansion of
the variable tmp via ${} this is done while reading the input.
if you want "lo" to change, you have to use a _reference_ to a
variable in the expression, i.e. v_tmp.
you can see it for yourself when running with -echo screen. lines with
immediate variable expansion will be printed repeatedly, once after
each individual expansion.
