Hello lammps users. I am using 9th october version of lammps.
I have the following code at the end of in.lj script to count the number of atoms and get the types of each atom
variable allatom equal count(all)
print {allatom}
variable i loop {allatom}
label looping
variable gettype equal type[i]
print {gettype}
print $i
next i
jump in.lj looping
The error is: Indexed per-atom vector in variable formula without atom map (…/variable.cpp:3541)
Although each index has an atom map
The following piece of code gives an error in another input script of mine: Invalid variable in next command, Although I could not find any fault
variable a loop ${N_0}
label looping
variable x equal type[$a]
print $a
print $x
next a
jump in.test looping
Also I am experiencing weird behaviour with looping in this version of lammps especially when the keyword type is involved.
Can someone please have a look ?
Arun
From: "S Arun Srikant Sridhar" <[email protected]...>
Date: Oct 29, 2014 11:53:18 AM
Subject: looping problems in recent version of lammps - ?
To: "[email protected]"
<[email protected]>
print \{allatom\}
label looping
variable gettype equal type[i\]
print {gettype}
print $i
next i
jump in.lj looping
(../variable.cpp:3541)
how do you know that? there is no indication in this input that there is.
label looping
print $a
print $x
next a
no problem here either.
