Hi all,
I have been trying to generate an a-SiO2 slab using a forcefield I found on a paper using lammps. First step is to melt a crystobalite sample. I am fairly new to lammps and my input file to melting a crystobalite slab is as below.
units real
atom_style full
pair_style hybrid/overlay buck 8.0 coul/wolf 0.231714 14.0
read_data crys.dat
pair_coeff 1 1 buck 64522.092 2.893 0.0 # SI-SI
pair_coeff 2 2 buck 25839.738 4.407 601.88949 # O-O
pair_coeff 1 2 buck 532886.67 5.098 3221.6077 # O-Si
pair_coeff * * coul/wolf
neighbor 2.0 bin
group mobile type 1 2
velocity mobile create 298 1103 dist gaussian
fix 1 mobile nve
fix 2 mobile press/berendsen iso 1.0 1.0 1000 modulus 360000
fix 3 mobile temp/berendsen 298 4000 100
timestep 1.0
run_style verlet
thermo_style custom step cpu temp pe ke press vol density lx ly lz
thermo 100
dump traj mobile xyz 100 melt.xyz
dump_modify traj element Si O
restart 500000 restart.1 restart.2
run 4000000type or paste code here
After running this I keep getting the following error.
Step CPU Temp PotEng KinEng Press Volume Density Lx Ly Lz
0 0 298 2.664738e+09 510.7618 1.8095785e+09 35332.099 0.54216622 21.0155 21.0155 80
ERROR: Lost atoms: original 576 current 574 (src/thermo.cpp:427)
Last command: run 4000000
can someone help me to resolve this error?
