I first tried equilibrating alumina atoms using NPT at 300 K and 1 bar. Then after that I an heating alumina from 300 K to 3000 K using NPT in restart input script. But around 2200 K I loose atoms . Melting point of alumna is around 2200 K
A part of my input script is here.
read_restart aluminaequil.in
#Define Potential
pair_style vashishta
pair_coeff * * AlO.vashishta Al O
timestep 0.005 #picoseconds
thermo 1
thermo_style custom step temp press vol etotal ke pe density
fix 3 all npt temp 300 3000 1.0 iso 1.0 1.0 1.0
run 200000
around 2200 K
there is not enough information here.
the manual describes causes that can cause lost atoms. see if any
apply to your simulation and resolve them.
Yes sir I tried using 0.5 femtosecond and my problem is resolved.
However I am not able to capture the melting point. I am trying to look potential energy/atom and mean square displacement variation with respect to temperature . i expect sudden change in slope of these parameters near the melting point.
Should i further reduce timestep?
Nikhil
Please open a new thread with an appropriate subject as the original problem has been resolved, thanks.
Melting point is a delicate property to capture using MD, and the approach you have taken is a rather crude one. It depends more on the heating rate than the timestep size.
The most reliable way of pin-pointing the melting point is to construct a bi-layer structure with co-existing liquid and solid phases and run it at different (constant) temperatures. Please consult the literature or your more experienced colleagues.
Ray
