Macro-nano coupling. Pressure inlet condition in LAMMPS
in my research about how a polymer gets into a nanocavity I am facing the following problem:
From a macro scale simulation carried out using Solidworks Plastics, I have a pressure profile (P with time). I want to use this pressure profile as a boundary condition in my LAMMPS simulation box but, as far as I know, it is not possible to define a pressure inlet boundary condition in molecular dynamics. So, how could I couple my pressure profile extracted from Solidworks with LAMMPS?
Maybe I should set a moving wall? However, at which speed?
Or maybe I should use the aveforce command at all the atoms of the simulation box? Should the force, then, be Pressure*Surface_of_inlet_wall?
Thanks in advance,
Jordi Pina
following problem:
that sounds much more reasonable and doable.
in the end, it is up to you.
you have to keep in mind, though, that there is no simple 1:1
translation from macroscopic models to atomic scale models.
There is a also a recently added fix controller command
which could be used to equilibrate the position of a wall
to induce a target pressure.
