Magnetic field code
I am a PhD student at Curtin university. I am looking for a lammps code to simulate water molecules under external magnetic fields. I tried to creat that code but I failed to do that. Additionally, I want to add different mineral ions to that system to evaluate the hydration shell behavior. So kindly support my request to solve this problem.
I am looking for your reply.
Regards
Ammar Al Helal
as mentioned several times before on this list, ​doing MD simulations under
the ​influence of a (static) magnetic field is decidedly non-trivial.
if you are unable to implement this yourself, then you are probably well
advised to discuss with your adviser to either find a different research
topic or an MD code that does implement this feature.
