dear all lammps user.
I want to simulate adsorption of hydrogen storage in CNT.
It already ran, but I think there’s some mistakes that I find yet.
I want to make the hydrogen move, so it can be catched by the CNT. but in simulation with VMD, hydrogen atoms have attraction each other.
I have already assign the initial velocity of hydrogen.
Can somebody help me??
best regards,
mardi
here’s the input script :
3-d LJ hydrogen storage
atom_style full
neighbor 0.3 bin
neigh_modify delay 5
compute mobile hyd temp
velocity hyd create 1.0 482748 temp mobile
fix 1 all nve
fix 2 hyd temp/rescale 100 0.26316 0.26316 0.02 1.0
fix_modify 2 temp mobile
You're using LJ units with an incredibly large
bond strength and a very small timestep.
What makes you think LJ coeffs of sigma,eps = 1.0
is a good model for hydrogen. With a cutoff of 3 sigma,
they will attract each other. Is this meant
to be a physical model for real materials
or an idealized system?
I’m using a Stillinger Weber potential in a simulation with various types of atoms, I wanted to know if the “neigh_modify exclude” command will correctly turn off the interactions between two types of atoms, because in the manual it says that it turn of pairwise interactions, but SW potential has olso the three body interaction term
I'm using a Stillinger Weber potential in a simulation with various types of
atoms, I wanted to know if the "neigh_modify exclude" command will correctly
it should do this, because the three body term
is computed by looping over the neighbors of the
second atom. so if the first pair interaction or
the second pair is excluded, nothing is computed.
i would still recommend to set up a few simplistic
test systems and verify this. this is very easy
to do and you can be a hundred percent certain
after doing this kind of test.
As always, I suggest you find a paper where
someone has modeled the system you are interested
in, learn how they did it, and start from there
before changing the model.
The definition of an "interaction" between 2 atoms
is fuzzy for many-body potentials.
Axel is correct that SW (and all the many-body potentials)
use pairwise neighbor lists to find interactions.
And the exclude settings will drop those pairwise
interactions from the list. However the 3-body term
in the SW case is actually a double loop over the
neighbors of atom I (not a loop over neighbors of J).
You'll have to decide if the
missing pairwise neighbors leave you with what you
desire in that case. In some many-body potentials
you could drop the A/C interaction from the pairwise
list but the 2 atoms would still "interact" thru B because
A/B and B/C interactions would still exist.
