I’m trying to compile and install the KIM API(kim-api-v1.6.3), but I get two error messages when I give the command “make”. I performed the installation in the following procedures according to the manual.
“kim-api-v1.6.3” is unzipped in $(HOME)
cp Makefile.KIM_Config.example Makefile.KIM_Config
vi Makefile.KIM_Config
I switched “KIM_DIR = $(HOME)/kim-api-v1.6.3” and “KIM_COMPILERSUITE = INTEL”. INTEL compiler is ver12.0
- To use "kcc_meam_LiSi__MO_596436139350_001” and “MEAM_2NN__MD_111291751625_001”, the former is unzipped in “examples/models” and the
latter in “examples/model_drivers”.
- make add- kcc_meam_LiSi__MO_596436139350_001
make add- MEAM_2NN__MD_111291751625_001
- make
When I carry out the command “make”, the following error messages appear.
This is a bug in the build system. Thanks for the report.
You can try the following fix:
Please replace the file
src/utils/Makefile
with the attached updated version and let me know if you have any further troubles.
Ryan Elliott
Makefile (6.58 KB)
Thanks for your reply.
After replace the file "kim-api-v1.6.3/src/utils/Makefile", the error by
the "make" disappeared, but probably the compilation does not completely
succeed.
In the first place the reason that is going to compile "kim-api-v1.6.3" is
because I want to simulate by using MEAM potential in
Lammps(lammps-10Jun14). That's why I am going to compile kim-api-v1.6.3
which I added "kcc_meam_……" and "MEAM_2NN_……" .
I compiled "kim-api-v1.6.3" in reference to the contents of the reply as
follows.
cd kim-api-v1.6.3
vi Makefile.KIM_Config # edit file as appropriate following the
instructions given in the INSTALL file
make add-kcc_meam_LiSi__MO_596436139350_001
make add-MEAM_2NN__MD_111291751625_001
make
make install
make install-set-default-to-v1
and the warning were not given.
Next, I replaced "lammps-10Jun14/src/KIM/Makefile.lammps" as follows
to use "pair_style kim" in Lammps.
kim_SYSINC = -I/usr/local/lib/kim-api-v1/include
kim_SYSLIB = -lkim-api -lkim-api-v1
kim_SYSPATH =-L/usr/local/lib
And after doing "make linux" in "/lammps-10Jun14/src", the following
errors were given.
You will need a newer version of LAMMPS to work with kim-api-v1.6.3.
The 6Aug14 version of lammps is the first that supports the kim-api-v1.6.X series...
Cheers,
Ryan
