Hi Dear Lammps users
Which make file should I use to make Parallel LAMMPS on redhat linux?
Cheers
RJ Ford
Cheers
RJ Ford
whatever suits your machine best.
"red hat" is a very vague description and many parallel machines are
heavily customized, so makefiles almost always need to be adjusted.
the LAMMPS documentation explains where and how.
if you do have a *stock* redhat 6.x machine, you can also try
installing the precompiled RPMs from here and save some time and
effort: http://git.icms.temple.edu/rpm/
