Many Body Polarization Force Field Polymer Electrolytes
Dear LAMMPS community,
I am interested in simulating ionic transport of magnesium electrolytes in poly(ethylene oxide) (PEO) in LAMMPS. Borodin and Smith demonstrated that using a many body polarizable force field is necessary for accurate dynamics, and developed a polarizable force field for PEO [1]. They implemented their force field using Lucretius MD code, which no longer exists (at least for free). Is the best/only way to implement this in LAMMPS to write a pair_style? Due to the form of the potential it would just consist of adding the polarization term to the buck/coul force field that already exists, I think.
Or would a different preexisting potential that includes polarization effects be better suited? Neither reaxFF or COMB3 support all the atoms types needed so some force development seems inevitable. Any suggestions are welcomed.
[1] Borodin, Oleg, and Grant D. Smith. "Development of quantum chemistry-based force fields for poly (ethylene oxide) with many-body polarization interactions."The Journal of Physical Chemistry B 107.28 (2003): 6801-6812.
Brandon Wood
​adding such a dipole polarization term could indeed be implemented ​as a
pair style and then combined with the buck/coul potentials via pair_style
hybrid/overlay
the important question is the range of the polarization interaction, i.e.
whether it needs to include long-range electrostatics or not. if they do,
things get complicated and probably an approach using a fix doing the
self-consistent part of the calculation in addition would be required
(similar to how it is done in COMB3).
are welcomed.
​to the best of my knowledge, the only similar feature in LAMMPS is support
for charge equilibration, which is applied to point charges and uses the
wolf-summation approach to approximate long-range​ electrostatics. i do
know of several attempts to implement the point dipole polarizable model of
Paul Tangney and Sandro Scandolo into LAMMPS, but so far have not seen any
usable code.
