mass assignment after restart
Hi all,
physical situation: plate (rigid) being dragged by a spring, shearing an underlying granular material.
If I restart my file (restart.equil) through the script in.shear i notice that
if I change the row 89
set group plate mass 500
by modifying “500” with “1000” (and I guess any other number) this does NOT affect the simulation. (this is the plate mass)
output: *.jpg -> screenshots | xcm.dat -> 2nd column is com of the plate
xcm.dat are identical for plate mass 500 and 1000 | this is not the case if not reloading
I apologise if I didn’t perform a thorough search on the mailing list for similar problems, the only one I found didn’t solve me the issue. I will do it tomorrow morning.
I am available for any further explanation
Regards
Mario
in.shear (2.9 KB)
restart.equil (215 KB)
It’s a complicated script, so not sure.
It should be OK to define fix rigid and
then set the particle masses afterwards,
so long as you do not do a “run” in between.
In fix rigid there is this line in setup():
setup_bodies_static();
If you add this line after it:
printf(“Mass total of body %g\n”,mass total[0])
you will see what total mass the single body has.
Thank you for the answer, Steve
I’m making some tries
M
