MC fix atom/swap invalid
I try the fix atom/swap command, with the example at http://lammps.sandia.gov/threads/msg58359.html, but LAMMPS
show me the error:
ERROR: Invalid fix style (…/modify.cpp:762)
Then, I checked the packages status with make ps, showing:
Installed YES: package MC
I do not understand what is wrong.
Could you help me with the problem?
Thanks very much!
B. L.
Did you recompile LAMMPS after installing the package? You can check to see if you have this fix by running “lmp -h”, it will be listed with the other fixes if you have it. If it is installed, there must be something wrong with the input, but the example looks correct to me.
show me the error:
ERROR: Invalid fix style (../modify.cpp:762)
did you recompile your LAMMPS executable after installing the package?
lammps-user:
Thank you for your reply.
The problem has been soluted via compiling the lasted version 16-Feb-16. I thought it maybe a bug fixed by new version.
Thank you.
B. L.
