When I use LAMMPS to run a pure MCMC simulation as,
fix 1 all gcmc 1 0 1 1 12345 1800 10.0 0.2
run 10000
I get total walltime of 0:01:18
. I would expect MD to have similar walltime (if not slower) for 10000 MD steps
fix nvt all nvt temp 1800.0 1800.0 $(100.0*dt)
run 10000
but I get 0:00:08
Detailed output is given below.
MCMC:
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 7.7544 | 7.7544 | 7.7544 | 0.0 | 9.94
Neigh | 17.265 | 17.265 | 17.265 | 0.0 | 22.13
Comm | 0.59392 | 0.59392 | 0.59392 | 0.0 | 0.76
Output | 0.0065886 | 0.0065886 | 0.0065886 | 0.0 | 0.01
Modify | 52.324 | 52.324 | 52.324 | 0.0 | 67.07
Other | | 0.07375 | | | 0.09
Nlocal: 512 ave 512 max 512 min
Histogram: 1 0 0 0 0 0 0 0 0 0
Nghost: 1436 ave 1436 max 1436 min
Neighs: 0 ave 0 max 0 min
FullNghs: 18578 ave 18578 max 18578 min
Total # of neighbors = 18578
Ave neighs/atom = 36.285156
Neighbor list builds = 30000
Dangerous builds = 0
System init for write_data ...
generated 0 of 0 mixed pair_coeff terms from geometric mixing rule
WARNING: Fix gcmc is being applied to the default group all (src/MC/fix_gcmc.cpp:657)
Neighbor list info ...
update every 1 steps, delay 10 steps, check yes
master list distance cutoff = 5.77118
ghost atom cutoff = 5.77118
binsize = 2.88559, bins = 8 8 8
1 neighbor lists, perpetual/occasional/extra = 1 0 0
(1) pair kim, perpetual
attributes: full, newton off, cut 5.77118
pair build: full/bin/atomonly
stencil: full/bin/3d
bin: standard
Total wall time: 0:01:18
MD
Pair | 7.8686 | 7.8686 | 7.8686 | 0.0 | 93.21
Neigh | 0.18398 | 0.18398 | 0.18398 | 0.0 | 2.18
Comm | 0.17472 | 0.17472 | 0.17472 | 0.0 | 2.07
Output | 0.0028456 | 0.0028456 | 0.0028456 | 0.0 | 0.03
Modify | 0.17596 | 0.17596 | 0.17596 | 0.0 | 2.08
Other | | 0.03559 | | | 0.42
Nghost: 1433 ave 1433 max 1433 min
FullNghs: 18630 ave 18630 max 18630 min
Total # of neighbors = 18630
Ave neighs/atom = 36.386719
Neighbor list builds = 151
bin: standard
Total wall time: 0:00:08
Is this expected? Given that MCMC does not need forces, and should have limited neighbor list recomputations, should it not be faster?
