I’m using mcsqs and trying to create a 96-atom monoclinic supercell (Space Group P21/c) for Yttria-Stabilized-Zirconia (YSZ, with 10mol% of Y2O3: 96 atoms, 26 Zr-, 6 Y-, 61 O-atoms and 3 O-vacancies). It nicely worked for the cubic cell and I was able to create some good structures with this tool, but I really don’t know what could be wrong when trying the monoclinic unit cell. I tried different ways to reach the goal, but always ended up with the following error:
Impossible to match point correlations due to incompatible supercell size.
What I did:
1.) To check if it works for the monoclinic unit cell I changed the rndstr.in cell parameters to the following values:
5.140000 5.200000 5.310000 90.00000 99.20000 90.00000
1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
0.070300 0.335900 0.340600 O=0.5,Vac=0.5
0.929700 0.664100 0.659400 O=0.5,Vac=0.5
0.929700 0.835900 0.159400 O=0.5,Vac=0.5
0.070300 0.164100 0.840600 O=0.5,Vac=0.5
0.557700 0.254900 0.021100 O=0.5,Vac=0.5
0.442300 0.745100 0.978900 O=0.5,Vac=0.5
0.442300 0.754900 0.478900 O=0.5,Vac=0.5
0.557700 0.245100 0.521100 O=0.5,Vac=0.5
0.275800 0.041100 0.208200 Zr=0.5,Y=0.5
0.724200 0.958900 0.791800 Zr=0.5,Y=0.5
0.724200 0.541100 0.291800 Zr=0.5,Y=0.5
0.275800 0.458900 0.708200 Zr=0.5,Y=0.5
Then I ran
corrdump -l=rndstr.in -ro -noe -nop -clus -2=4
mcsqs -n 96
changed the sqscell.out to:
1
2. 0. 0.
0. 2. 0.
0. 0. 2.
and after running "mcsqs -rc" I got my final SQS.
2.) Afterwards I changed the probabilities/occupancies for Zr and Y in the rndstr.in to the desired values for the 96-atom cell,
0.275800 0.041100 0.208200 Zr=0.8125,Y=0.1875
0.724200 0.958900 0.791800 Zr=0.8125,Y=0.1875
0.724200 0.541100 0.291800 Zr=0.8125,Y=0.1875
0.275800 0.458900 0.708200 Zr=0.8125,Y=0.1875
did all steps from above again and it worked quite well.
3.) As final step I changed the values for O and O-vacancies:
0.070300 0.335900 0.340600 O=0.953125, Vac=0.046875
0.929700 0.664100 0.659400 O=0.953125, Vac=0.046875
0.929700 0.835900 0.159400 O=0.953125, Vac=0.046875
0.070300 0.164100 0.840600 O=0.953125, Vac=0.046875
0.557700 0.254900 0.021100 O=0.953125, Vac=0.046875
0.442300 0.745100 0.978900 O=0.953125, Vac=0.046875
0.442300 0.754900 0.478900 O=0.953125, Vac=0.046875
0.557700 0.245100 0.521100 O=0.953125, Vac=0.046875
Running "mcsqs -n 96" again, delivers the error from the top of the page. :?:
I also tried the steps mentioned in https://www.brown.edu/Departments/Engineering/Labs/avdw/forum/viewtopic.php?f=4&t=306&p=1544&hilit=incompatible#p1544, but nothing seems to help solving my problem.
I found out, that it works for 192=2*96 atoms. I think this works due to the fact that 192 times the probabilities from the rndstr.in results in an integer and the calculation with 96 doesn’t. On the other hand the O-sublattice in the 96-atom cell should contain 64 positions, which will lead to integer values too concerning the probabilities. That’s what I thought was right and what should be fulfilled when calculating the probabilites for the sublattice. So I’m not sure what exactly could lead to this error and would appreciate any help, thank you.
