MD result analysis
I have a question for asking. For DFT calculation, the result is N adatom will have a strong bond with N atom on m-plane. But for MD simulation, N adatom always like to bind with Ga atom on m-plane, I have also tesed the N-N ;Ga-N; Ga-Ga interactions with respect of distance, N-N is the stongest, how to understand in MD, N prefer to form bond with Ga on surface?
Best
XJ
What potential are you using in MD, and how
are you determining it "likes to bind" in the MD?
Hi, I used Tersoff potential for GaN
For DFT calculation, the results show N adtoms have a strong interaction with N than Ga on surface, and they say N will form N-N bond.
but for MD results, all N adatoms bond with Ga on surface, not as DFT results show N like to bond with N atom on surface
I just see the results that N adatoms have bond with Ga on surface each frame.
Best
XJ
Well, maybe the parameterization of Tersoff you are using
isn't a good one for this model. I would look in the
literature to see if others have modeled these surfaces
this way.
Hi, many thanks for your reply.
GaN tersoff potential I used is from ref. J. Phys.: Condens. Matter 15 (2003) 5649–5662
the DFT calculation I compared is from ref. PHYSICAL REVIEW B 79, 241308(R) (2009)
Best
XJ
