MD simulation for 3d polydisperse system
How i will do a Molecular dynamics simulation of 3d polydisperse (with 11% polydispercity) system using LJ potential in lammps. Mainly my question is how i will assign the different diameter in lammps as my system is polydisperse.
My main question how i assign the pair_coeff for different paricles. Because here all particle has different diameter.
Here is my script how i modify it:
restart 3000000 restart.3dAMLJ_60
units lj #all quantities are expressed in terms of Lennard Jones parameters
atom_style atomic
neighbor 0.3 bin
neigh_modify delay 4
lattice fcc 0.82
region box block 0 13 0 13 0 13
#create_box 2 box
create_atoms 1 box #initial position
#mass 1 1.0
pair_style lj/cut 2.5
pair_coeff x y \epsilon \sigma cut_off #(/ Here All particles has different sigma)
compute new liq temp
print "Seed: {seed}" velocity liq create 0.0080 {seed} temp new
fix 1 liq nvt temp 0.0080 0.0080 0.1
timestep 0.005 #delta T
thermo 10000 #output
thermo_modify temp new
run 199904
reset_timestep 0
thermo 100000 #output
variable f1 file tmp.txt
variable s equal next(f1)
dump 3 liq custom 1 dump.liq x y z type
dump_modify 3 every v_s sort id
run 199904
Tahnotan
polydisperse.
​for each atom with a different sigma, you need to reserve an atom type.
correspondingly you need to assign a pair_coeff​ statement to each pair of
atom types.
the latter can be mostly automated, if you can apply a mixing rule for the
mixed interactions.
example. for three atom types, it may be sufficient to specify:
pair_coeff 1 1 1.0 1.0
pair_coeff 2 2 1.0 1.5
pair_coeff 3 3 1.0 2.0
...and then LAMMPS will compute the remaining pairs:
1 2, 1 3, 2 3 from mixing. for details on that, please see the
documentation for pair_modify
