Dear LAMMPS users,
Hello.
I have tried to run the simulation with TIP4P2005 water model.
After several trial and error, I can run the simulation successfully without error or warning.
The shake works well, which make the bond length and bond angle of TIP4p water molecules constant.
PPPM/tip4p also seems to work fine and temperature is well maintained.
But the problem is that the water molecules don’t move.
When I look into the log file and thermo data, those have same values for each step.
Even though temperature of system is increased to 350K, the result is same.
I can’t find where the problem exist.
Is there any fault in my input data or input script?
(please find the attached files).
Thank you very much.
Sehun Joo
Define variables
input data file
variable lmp_data string data.water
temperature and pressure
variable T equal 350
variable p equal 3/0.101325
interactions / rcut
variable rcut equal 12
number of steps / timestep
variable nstep equal “10000000”
variable dt equal 2
output
variable freq_thermo equal “100” # thermo output every
variable freq_frame equal “10000” # frame output every
variable freq_snap equal “v_nstep/10” # xyz output every for safety (rerun)
Initialization
units real
atom_style full
Force Field
read_data ${lmp_data}
#replicate 5 5 5
1 WH
2 WO
mass 1 1.008
mass 2 15.9994
pair_style lj/cut/tip4p/long 2 1 1 1 0.1546 ${rcut}
pair_modify mix arithmetic
pair_coeff 1 1 0 0
pair_coeff 1 2 0 0
pair_coeff 2 2 0.1852 3.1589
1 WH-WO
bond_style harmonic
bond_coeff 1 900 0.9572
5 WH-WO-WH (fix)
angle_style harmonic
angle_coeff 1 124 104.52
Coulomb interaction
kspace_style pppm/tip4p 1.0e-4
#special_bonds lj/coul 0.0 0.0 0.0
group o type 2
group water type 1 2
Constraints
fix fixtip4p all shake 0.0001 20 10 b 1 a 1
1. RELAX / NVT
velocity all create $T 87654 dist gaussian mom yes rot yes
fix thermostat all temp/berendsen {T} {T} 100.0
#fix barostat all press/berendsen aniso {p} {p} 1000.0
thermo ${freq_thermo}
thermo_style custom step cpuremain temp press etotal pe ke epair ecoul evdwl ebond eangle edihed
thermo_modify flush yes
dump dtrj all custom 100 ${lmp_data}.lammpstrj id type x y z mol
dump dsnap all custom {freq_frame} {lmp_data}_*.lammpstrj id type x y z mol
dump dxyz all xyz 100 ${lmp_data}_*.xyz
dump_modify dxyz element H O
reset_timestep 0
timestep ${dt}
run 50000
undump dtrj
undump dsnap
write_restart restart.RELAX01
print “01.RELAX done”
data.water (30.7 KB)
in.water (2.8 KB)
