I am going to use the meam potential. I build the MEAM package as the way in the readme file and it works in LAMMPS.
The problem is that I am going to build lammps as a library and use it by my own code. I did it in this way:
you need to link with the gfortran compiler runtime library when you compile your own binary. Makefile.lammps is not applied since you are linking manually. as mentioned before, you must study very carefully how the LAMMPS executable is linked and you will know what you have to do.
