meaning of comm_forward/comm_reverse
Hi all,
Just want to have a quick sanity check. In pair.h or compute.h, the following variables are declared:
int comm_forward; // size of forward communication (0 if none)
int comm_reverse; // size of reverse communication (0 if none)
Am I right to think that the size here is the buffer size, i.e. for the MPI communication? Some of them have comm_forward (or reserve) value set to 1 or 2, others have set them to the exact value on the nlocal, which makes me a bit confused.
Quang
Hi all,
none)
none)
me a bit confused.
​please where is comm_forward​/comm_reverse set to natoms? it doesn't make
sense. i suspect you are misreading the source code.
the sizes here for forward/reverse communication are *per atom* buffer
sizes, i.e. how many items are packed into the corresponding buffer per
atom.
