Dear Lammps community,
I hope you are doing well.
I need to measure the electrical potential of my system (which is a polyelectrolyte network aka hydrogel)
I have bumped into Andrew Jewett’s post on the easiest way of doing that: using a dummy probe atom and subtracting the potential energy before vs after the inserted.
I have a couple of questions though:
How would you verify the obtained potential. (what kind of model system will you use to compare calculated data with the theoretical predictions)
How do you make sure that there is no overlap in the system when you insert the ghost atom.
The way I setup my simulation is to create an atom inside lammps and use run 0 to calculate the energy. Andrew Jewett mentions one could use rerun command. will it make any difference?
create_atoms 4 single $x $y $z units box
pair_coeff 4 * 0. 0.
group probes type 4
set type 4 charge 1.
run 0
variable tmppe equal ecoul
variable mype equal v_tmppe
print “$x $y z {mype}” append info_${infile}.dat
delete_atoms group probes
Thank you,
Vasilii.
