Dear Axel and all users
i search about nanoparticle melting point around 10 days in mailing
list but I could not find any useful answer
this is my script
atom_style atomic
atom_modify map array
read_data 256b.data
pair_style hybrid/overlay lj/cut 14.0 eam
pair_coeff 2 2 eam Au_u3.eam
pair_coeff 1 1 lj/cut 0 0
pair_coeff 1 2 lj/cut 0.048427138 3.187
neighbor 0.3 bin
neigh_modify every 5 delay 0 check no
group CA type 1
group AU type 2
velocity CA set 0.0 0.0 0.0
# ---------- Define Settings ---------------------
compute eng all pe/atom
compute eatoms all reduce sum c_eng
compute myRDF AU rdf 100
fix 1 AU ave/time 100 10 1000 c_myRDF[*] file tmp.rdf mode vector
# ---------- Run Minimization ---------------------
reset_timestep 0
fix 2 all box/relax iso 0.0 vmax 0.001
thermo 20000
minimize 0 0 1000 1000000
min_style cg
#-----------------dynamic run in new temperature
dump nvt all xyz 1000 ionized-nvt.xyz
velocity all create 200 39849 mom yes rot yes dist gaussian
compute AU AU temp
fix 3 all ave/time 100 10 20000 c_AU file temp.txt mode scalar
thermo_style multi
timestep 0.0001
fix 4 AU nvt temp 200.00 200.00 0.001
run 100000
unfix 4
fix 5 AU nvt temp 200.00 1600.00 0.01
run 500000
unfix 5
fix 6 AU nvt temp 1600.00 1600.00 0.1
run 100000
unfix 6
fix 7 AU nvt temp 1600 200.00 0.01
run 500000
unfix 7
undump nvt
but when simulation done and draw potential v.s temperature curve i
see not any jump energy that show nanoparticle melt
what must i do?
