I am currently polishing the openKIM integration in potfit, which has been
contributed by Mingjian Wen. However, for certain routines I get memory leaks,
which I don’t know how to fix.
Basically I just want to query some model parameters and not initialize
or setup any calculation. Here is some pseudo-code:
void consume_memory()
void* pkim = NULL;
KIM_API_model_info(&pkim, model_name);
int descriptor_str_len = 0;
KIM_API_get_model_kim_str_len(model_name, &descriptor_str_len);
char * descriptor_str = NULL;
KIM_API_get_model_kim_str(model_name, &descriptor_str);
int numfreeparams = 0;
int maxstringlength = 0;
KIM_API_get_num_free_params(pkim, &numfreeparams, &maxstringlength);
// do some stuff with the descriptor string here
free(descriptor_str);
After calling this method there is about 50k memory which is not released:
==32522==ERROR: LeakSanitizer: detected memory leaks
Indirect leak of 33784 byte(s) in 1 object(s) allocated from:
#0 0x7f5e79c85622 in operator new[](unsigned long) (/usr/lib/gcc/x86_64-pc-linux-gnu/5.4.0/libasan.so.2+0x99622)
#1 0x7f5e7999d230 in KIM_API_model::prestring_init(char const*) /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:825
Indirect leak of 5096 byte(s) in 1 object(s) allocated from:
#1 0x7f5e799a4359 in KIM_API_model_info /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API_C.cpp:124
Indirect leak of 4992 byte(s) in 39 object(s) allocated from:
#0 0x7f5e79c854a2 in operator new(unsigned long) (/usr/lib/gcc/x86_64-pc-linux-gnu/5.4.0/libasan.so.2+0x994a2)
#1 0x7f5e799849ae in KIMBaseElement::init(char const*, char const*, long, long, int*, void*) /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:451
#1 0x7f5e79984a12 in KIMBaseElement::init(char const*, char const*, long, long, int*, void*) /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:454
Indirect leak of 3040 byte(s) in 38 object(s) allocated from:
#1 0x7f5e7999cf04 in KIM_API_model::prestring_init(char const*) /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:796
Indirect leak of 624 byte(s) in 39 object(s) allocated from:
#1 0x7f5e7998497b in KIMBaseElement::init(char const*, char const*, long, long, int*, void*) /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:449
Indirect leak of 547 byte(s) in 39 object(s) allocated from:
#1 0x7f5e799849e6 in KIMBaseElement::init(char const*, char const*, long, long, int*, void*) /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:452
Indirect leak of 328 byte(s) in 1 object(s) allocated from:
#1 0x7f5e79985b05 in KIMBaseElement::init(char const*, char const*, long, long, int*) /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:498
Indirect leak of 192 byte(s) in 7 object(s) allocated from:
#1 0x7f5e79987d1f in KIM_API_model::KIM_API_model() /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:703
Indirect leak of 136 byte(s) in 1 object(s) allocated from:
#1 0x7f5e7998efc4 in KIM_API_model::init_AtomsTypes() /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:2678
Indirect leak of 56 byte(s) in 1 object(s) allocated from:
#1 0x7f5e799879bf in KIM_API_model::KIM_API_model() /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:693
#1 0x7f5e79987950 in KIM_API_model::KIM_API_model() /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:692
Indirect leak of 28 byte(s) in 1 object(s) allocated from:
#1 0x7f5e799878e1 in KIM_API_model::KIM_API_model() /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:691
Indirect leak of 16 byte(s) in 2 object(s) allocated from:
#1 0x7f5e79984ad5 in KIMBaseElement::init(char const*, char const*, long, long, int*, void*) /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:475
Indirect leak of 16 byte(s) in 4 object(s) allocated from:
#1 0x7f5e79984ca9 in KIMBaseElement::init(char const*, char const*, long, long, int*, void*) /home/daniel/workspace/potfit_openkim/kim-api-v1.7.3/src/KIM_API.cpp:466
SUMMARY: AddressSanitizer: 53903 byte(s) leaked in 214 allocation(s).
I cannot find any API method which would clean up this memory.
KIM_API_model_destroy and KIM_API_free both result in a segmentation fault
because they probably should not be called here.
Is there any way to release this memory?
I guess I could not call KIM_API_model_info and KIM_API_get_num_free_params
and then calculate numfreeparams and maxstringlength myself.
Daniel
