I have some problem with the method eps because when I launch the simulation, I have logical value for stress at the beginning but after,temperature increases strongly and the computation can´t be made :
100 0 36.15723 0
1000 45.951168 36.15723 0.63390809
2000 99.088874 36.15723 0.1213101
3000 149.74134 36.15723 0.6776301
4000 203.82692 36.15723 4.9518453
5000 nan 36.244641 nan
6000 nan 36.244641 nan
7000 nan 36.244641 nan
I tried by decreasing the timestep even until 10-8 but it didn´t work.
Do you have any idea to solve this numerical problem ?
Thanks for your consideration
Simon Bourreau
INPUT File :
# 3D peridynamic simulation for traction
units nano
boundary s s s
atom_style peri
atom_modify map array
neighbor 0.1 bin
lattice sc 0.3615
#define all the parts
region beam block 0 36.15 0 2.169 0 2.169 units box
create_box 1 beam
create_atoms 1 region beam
region leftbc block 0 1.0845 0 2.169 0 2.169 units box
group leftbc region leftbc
region rightbc block 35.0655 36.15 0 2.169 0 2.169 units box
group rightbc region rightbc
group boundary union leftbc rightbc
group middle_atoms subtract all boundary
pair_style peri/eps
pair_coeff * * 37000 27750 1.0845 2.6 0.1 40
set group all density 8960e-6
set group all volume 0.047241
run 100
velocity all set 0.0 0.0 0.0 sum no units box
fix 1 middle_atoms nve
compute peratom middle_atoms stress/atom NULL
compute sigmaxx middle_atoms reduce sum c_peratom[1]
variable sigmavolxx equal c_sigmaxx/(0.94*vol)
fix 2 rightbc move linear 1.8075 0 0 units box
fix 3 leftbc move linear -1.8075 0 0 units box
timestep 0.005e-3 #0.005
thermo 1000
thermo_style custom step v_sigmavolxx lx temp
dump 1 all custom 4100 peri_6_nano_eps_res.txt id x y z
dump_modify 1 append yes
run 20000
# SIMULATION DONE
print "All done"
