Micelle formation in SDS example
Hi!
I’m talking about the SDS example in the USER/cg-cmm folder. When I simulate it, I get to see only a monolayer formation. Could I get the source code for the same? What should I be doing to reach the micelle formation from the already existing monolayer? Please help
Regards,
Prapti
There are two example inputs in the “cg-cmm” folder, very recently renamed to “cgsdk”. One is “peg-verlet” and the other is aptly named “sds-monolayer”.
If you need a micelle, you should initialize an aqueous mixture with a low concentration of SDS. You are very unlikely to get it from the air/SDS/water interfacial system of the example.
Giacomo
