minimizing and using the relaxed structure
      It might be very stupid question but please bear with me :-). I want to use relaxed structure for my further calculations but also want to look at and work with relaxed structure (that's why I don't want to use minimize and run in the same file). Here is what I do:
1. Minimize the structure
2. Edit output structure file and make it compatible as a input structure file (see question relating to this step below)
3. Run the further simulation
My Questions:
1. My rlx.str file generates structure twice and also output coordinates are fractional (between 0-1). Can I use it as it is? I did make changes and wrote input structure file but program is giving error message "unexpected end of data file". even though I have all the atoms are there.
2. Is there any better way to write output structure after minimization is complete.
3. As I want to further introduce vacancy in the system, can I just choose one atom by its coordinates to delete ?
Thanks in advance
~Priyank
Here is my input script for minimization
Comments below.
My Questions:
undoubtably the format of your data file is incorrect. LAMMPS wouldn't
complain if it wasn't. See the read_data doc page.
is complete.
As with any LAMMPS simulation, you can write out dump or restart files
at the end of a minimization. You have to cut/paste coords from a dump
file into a data file. The tools/restart2data code will convert a restart
file to a data file.
You can just whack a line from the data file if you like. Or use
the delete_atoms command in an input script.
