Dear LAMMPS users,
I wrote the code which deletes atoms in the post_force step, at the
end I do the following:
bigint nblocal = atom->nlocal;
MPI_Allreduce(&nblocal, &atom->natoms, 1, MPI_LMP_BIGINT, MPI_SUM, world);
if (atom->map_style)
atom->nghost = 0; //it looks like it is not necessary here
atom->map_init();
atom->map_set();
//neighbor->build();
When after that, I, for instance, write to restart or do other
operations with bobds, than the message "Bonds are missing occurs"
from the code
for (i = 0; i < nlocal; i++)
for (m = 0; m < num_bond[i]; m++) {
atom1 = atom->map(bond_atom[i][m]);
if (atom1 == -1) {
char str[128];
sprintf(str, "Bond atoms %d %d missing on proc %d at step "
BIGINT_FORMAT,
tag[i],bond_atom[i][m],me,update->ntimestep);
error->one(FLERR,str);
Because, not surprisingly, atom1 == -1. But when Neighbor::bond_all
is called from the verlet code, this atom1 is initialized and not -1.
Do you know where exactly this initialization happens so map is valid
again and map(bond_atom[i][m]) != -1? I want to call it after deleting
atoms to have get rid of this error.
