Dear Lammps Users:
May I ask if you encountered a problem with missing lmpinstalledpkgs.h? Seems it is a new header file added in the newly released patch. Without it, I cannot compile Lammps successfully. Thank you.
Jiaoyan
Dear Lammps Users:
Jiaoyan
Dear Lammps Users:
this file should be automatically generated during compilation or configuration, depending on whether you use the conventional build system or the new cmake based build system.
if it is not, you are likely not following the required installation instructions. please provide more details about where you obtained LAMMPS, how you configure and compile it, and also what OS/platform/compiler you are compiling on and with.
Axel,
Thanks a lot for your reply. I have modified my Makefile and now I can compile LAMMPS successfully. Thank you so much for pointing this out.
Jiaoyan
