How to use ‘mlaunch’ in reservation mode? Once I change the my_qadapter.yaml to use ‘mlaunch’ instead of ‘rlaunch’ with appropriate commands, how should I submit to the queue? qlaunch -r singleshot or qlaunch -r rapidfire doesn’t seem to work. (I am using v1.04 of FWS)
You cannot use mlaunch in reservation mode. The point of reservation mode is to tailor the queue script to a single job. With mlaunch, there will be multiple jobs that get pulled and the queue script cannot be specific to a single job.
You can, however, make sure that mlaunch only pulls a particular “type” of job. e.g., let’s say you have mixed job type in the database and want mlaunch to only pull a certain type. You can use the FireWorker options to make sure that only certain jobs are being run within mlaunch. See the last part of “http://pythonhosted.org/FireWorks/multi_job.html” for more details.
If that’s not helpful, maybe you can describe a bit of what you’re trying to accomplish.
Anubhav
On Thu, Jun 4, 2015 at 9:32 AM, Panchapakesan Ganesh [email protected] wrote:
You received this message because you are subscribed to the Google Groups “fireworkflows” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To view this discussion on the web visit https://groups.google.com/d/msgid/fireworkflows/bf8957bc-1651-49cb-98e3-64ab6cf170a2%40googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
Thanks Anubhav. What I am trying to do is to bundle multiple fireworks, with similar computing requirements, using ‘mlaunch’ into one PBS job that can be submitted to a PBS queue, with the mongoDB hosted on a different server (such as the mongo-cloud service) than the fworker.
Ganesh
Anubhav
I need the offline/reservation mode because my compute nodes cannot connect to the launchpad. In cases (clusters) where they do, the mlaunch works fine as you prescribed. --Ganesh
Ganesh
Anubhav
Ok, I understand; unfortunately, there is so far no way to run mlaunch in offline mode. To do this, one would need to pre-generate many FW.json files and then mlaunch would need to select from that pool of pregenerated files. It is certainly possible, but I would put this in the category of something that an outside user would need to lead the development of.
Anubhav
On Fri, Jun 5, 2015 at 11:33 AM, Panchapakesan Ganesh [email protected] wrote:
Ganesh
Anubhav
To view this discussion on the web visit https://groups.google.com/d/msgid/fireworkflows/257c93c8-0855-44d5-bb22-caa4ad0e77df%40googlegroups.com.
