I am testing the mlaunch application to process FireWorks in parallel.
The test case I am running is a slightly modified version of the workflow tutorial in which the two Fireworks that can be run in parallel (and part of a diamond shaped workflow) execute a sleep command for 10s:
fws:
fw_id: 1
spec:
_tasks:
_fw_name: ScriptTask
script: echo ‘Ingrid is CEO.’
fw_id: 2
spec:
_tasks:
script: sleep 10
fw_id: 3
spec:
_tasks:
script: sleep 10
fw_id: 4
spec:
_tasks:
script: echo ‘Kip is an intern.’
links:
1:
2
3
2:
- 4
3:
- 4
metadata: {}
When running this command as follows on a Ubuntu 12.04 (vagrant) VM with 4 assigned processors:
mlaunch 4 --nlaunches infinite
It quickly prints a warning message to the screen:
[email protected]:/vagrant_data/Code/fireworks/fw_tutorials/workflow$ mlaunch 4 --nlaunches infinite
/home/vagrant/anaconda/lib/python2.7/site-packages/pymongo/topology.py:75: UserWarning: MongoClient opened before fork. Create MongoClient with connect=False, or create client after forking. See PyMongo’s documentation for details: http://api.mongodb.org/python/current/faq.html#using-pymongo-with-multiprocessing>
"MongoClient opened before fork. Create MongoClient "
2016-04-15 12:46:12,488 INFO Created new dir /vagrant_data/Code/fireworks/fw_tutorials/workflow/launcher_2016-04-15-16-46-12-486964
2016-04-15 12:46:12,489 INFO Launching Rocket : (Process-2)
2016-04-15 12:46:12,541 INFO RUNNING fw_id: 1 in directory: /vagrant_data/Code/fireworks/fw_tutorials/workflow/launcher_2016-04-15-16-46-12-486964
2016-04-15 12:46:12,612 INFO Sleeping for 60 secs : (Process-3)
2016-04-15 12:46:12,711 INFO Task started: ScriptTask.
Ingrid is CEO.
2016-04-15 12:46:12,715 INFO Task completed: ScriptTask
2016-04-15 12:46:12,760 INFO Sleeping for 60 secs : (Process-4)
2016-04-15 12:46:12,903 INFO Rocket finished : (Process-2)
2016-04-15 12:46:12,909 INFO Created new dir /vagrant_data/Code/fireworks/fw_tutorials/workflow/launcher_2016-04-15-16-46-12-908343
2016-04-15 12:46:12,910 INFO Launching Rocket : (Process-2)
2016-04-15 12:46:12,926 INFO Created new dir /vagrant_data/Code/fireworks/fw_tutorials/workflow/launcher_2016-04-15-16-46-12-925160
2016-04-15 12:46:12,928 INFO Launching Rocket : (Process-5)
2016-04-15 12:46:12,945 INFO RUNNING fw_id: 2 in directory: /vagrant_data/Code/fireworks/fw_tutorials/workflow/launcher_2016-04-15-16-46-12-908343
2016-04-15 12:46:12,981 INFO RUNNING fw_id: 3 in directory: /vagrant_data/Code/fireworks/fw_tutorials/workflow/launcher_2016-04-15-16-46-12-925160
2016-04-15 12:46:13,114 INFO Task started: ScriptTask.
2016-04-15 12:46:13,146 INFO Task started: ScriptTask.
2016-04-15 12:46:33,119 INFO Task completed: ScriptTask
2016-04-15 12:46:33,151 INFO Task completed: ScriptTask
2016-04-15 12:46:33,301 INFO Rocket finished : (Process-2)
2016-04-15 12:46:33,340 INFO Rocket finished : (Process-5)
2016-04-15 12:46:33,346 INFO Created new dir /vagrant_data/Code/fireworks/fw_tutorials/workflow/launcher_2016-04-15-16-46-33-345288
2016-04-15 12:46:33,347 INFO Launching Rocket : (Process-5)
2016-04-15 12:46:33,368 INFO RUNNING fw_id: 4 in directory: /vagrant_data/Code/fireworks/fw_tutorials/workflow/launcher_2016-04-15-16-46-33-345288
2016-04-15 12:46:33,454 INFO Sleeping for 60 secs : (Process-2)
2016-04-15 12:46:33,534 INFO Task started: ScriptTask.
Kip is an intern.
2016-04-15 12:46:33,539 INFO Task completed: ScriptTask
2016-04-15 12:46:33,716 INFO Rocket finished : (Process-5)
2016-04-15 12:46:33,870 INFO Sleeping for 60 secs : (Process-5)
2016-04-15 12:47:12,628 INFO Checking for FWs to run… : (Process-3)
2016-04-15 12:47:12,629 INFO Sleeping for 60 secs : (Process-3)
2016-04-15 12:47:12,780 INFO Checking for FWs to run… : (Process-4)
2016-04-15 12:47:12,782 INFO Sleeping for 60 secs : (Process-4)
The two targeted Fireworks are indeed run in parallel. So far so good. Once the final Firework has completed, seemingly, the workers continue to look for remaining Fireworks to execute, although the workflow has completed. I cannot exit the application as it has slipped into some kind of deadlock state.
My version of
pymongo: 3.2.2
fireworks: 1.2.7
Any suggestions?
