I am trying to predict the magnetic order transformations in Mn doped SmFeO3 using the MagneticStructureEnumerator class. However I am getting the error [WinError 193] %1 is not a valid Win32 application. How do I resolve this issue?
Attached is the complete discription of the error
OSError Traceback (most recent call last)
in
37 from pymatgen.transformations.advanced_transformations import MagOrderingTransformation
38 mag_par = MagOrderingTransformation({“Sm3+”:5,“Fe3+”:5,“O2-”:0,“Mn3+”:4}, order_parameter=0.5)
—> 39 SmFeO3_Mn_Mag_new = mag_par.apply_transformation(SmFeO3_Mn_prop)
40 print(SmFeO3_Mn_Mag_new)
~\anaconda3\lib\site-packages\pymatgen\transformations\advanced_transformations.py in apply_transformation(self, structure, return_ranked_list)
940 t = EnumerateStructureTransformation(**enum_kwargs)
941
→ 942 alls = t.apply_transformation(structure, return_ranked_list=return_ranked_list)
943
944 # handle the fact that EnumerateStructureTransformation can either
445 )
446 try:
→ 447 adaptor.run()
448 except EnumError:
449 warn(“Unable to enumerate for max_cell_size = {}”.format(max_cell_size))
~\anaconda3\lib\site-packages\pymatgen\command_line\enumlib_caller.py in run(self)
140 self._gen_input_file()
141 # Perform the actual enumeration
→ 142 num_structs = self._run_multienum()
143 # Read in the enumeration output as structures.
144 if num_structs > 0:
~\anaconda3\lib\site-packages\pymatgen\command_line\enumlib_caller.py in _run_multienum(self)
292 def _run_multienum(self):
293
→ 294 p = subprocess.Popen([enum_cmd],
295 stdout=subprocess.PIPE,
296 stdin=subprocess.PIPE, close_fds=True)
~\anaconda3\lib\subprocess.py in init(self, args, bufsize, executable, stdin, stdout, stderr, preexec_fn, close_fds, shell, cwd, env, universal_newlines, startupinfo, creationflags, restore_signals, start_new_session, pass_fds, encoding, errors, text)
852 encoding=encoding, errors=errors)
853
→ 854 self._execute_child(args, executable, preexec_fn, close_fds,
855 pass_fds, cwd, env,
856 startupinfo, creationflags, shell,
~\anaconda3\lib\subprocess.py in _execute_child(self, args, executable, preexec_fn, close_fds, pass_fds, cwd, env, startupinfo, creationflags, shell, p2cread, p2cwrite, c2pread, c2pwrite, errread, errwrite, unused_restore_signals, unused_start_new_session)
1305 # Start the process
1306 try:
→ 1307 hp, ht, pid, tid = _winapi.CreateProcess(executable, args,
1308 # no special security
1309 None, None,
OSError: [WinError 193] %1 is not a valid Win32 application
