Modeling cooling due to heat transfer with walls
the following question has must to do with MD concepts than with LAMMPS itself, but since I think you can help me I ask it here :slight_smile:
I am interested in modeling how a wall at a fixed temperature (300K) cools a polymer initially at a higher temperature down to the walls temperature of 300K.
For doing so I have defined an atomistic wall that consists on a FCC Fe structure.
As fas as I know, I have to thermostat the wall. I am currently doing this via a Langevin thermostat and NVE for time integration.
The movement of the polymer through the wall is modeled via an aveforce command and a NPT thermostat.
Is all of the above an acceptable approach? Could you give me some insight on how to approach it?
Thanks in advance.
I am struggling with this problem without success.
Initially I have the polymer above a FCC structure. The FCC structure has a hole in which I want to introduce the polymer.
First of all I minimize the polymer structure and next to it I run an equilibration run:
I have discovered that by changing the command:
fix 6 polymer_group addforce 0 0 -3
for
fix 6 polymer_group addforce 0 0 -0.0001
The error doesn’t appear, however, I don’t observe any cooling of the polymer due to heat transfer with the walls.
for
The error doesn't appear, however, I don't observe any cooling of the
have you made an estimate of what amount of energy would be
transferred for the duration of your simulation?
