modify write_restart command to repeat same simulation
Since the neighbor lists will be rebuilt whenever lammps write a restart file, the result of two simulation with different write_restart tilmestep will be different statistically.
The material I simulated behaves differently because of this.
If I modify the write_restart.cpp file by deleting the following two lines, will I be able to repeat same simulation ?
comm->exchange();
comm->borders();
Regards,
Wenting
The reason LAMMPS rebuilds neighbor lists on a timestep
when a restart file is written is so that when you restart
you get as close as possible the original simulation had it
continued on. E.g. if you run a simulation for 2N steps
and write a restart file on step N, then read the restart
file and run for N more steps, it should be similar
to the 2N result of the first run. Of course if N is large,
or you perform the 2nd run on a different # of procs,
or you use random numbers (e.g. fix langevin) then
things will always diverge statistically.
So there is no simple answer to this Q:
comm->exchange();
comm->borders();
So I don’t suggest you do that. Also re: this comment:
That’s a “feature” of MD and reality. If you do 2 runs
and they give different results (statistically only),
you can’t say either is right. “Right” is the average
of the statistical ensemble.
Hi Steve,
Thank you for your answer. I understand now. So even though I managed to delete the neighbor rebuild process somehow when the restart file is written, the restart file generated accordingly is meaningless and can’t be used to continue the simulation.
Regards,
Wenting
I didn’t say the restart file you wrote out was meaningless.
It could be fine to read it back in and continue on.
I said I think you are worrying about exact restarts when
you don’t need to be.
