Moltemplate data file problem
Dear all ,
I have a problem and i will be grateful if you can answer it .
I tried to make data file for an aromatic molecule with Moltemplate , after that when i want to check it by VMD and TopoTools with this code :
topo readlammpsdata Aromatic.data full
there is no problem but when i want to start doing MD simulation at the first step i see that this molecule is not like that and there is some dissociation inside of it .
Can you please let me know what the problem is ?
Regards,
Saeed.
Dear all ,
the main problem is that nobody can give advice on such an extremely
vague description.
nobody here has a crystal ball or is a mind reader.
Hi .
I am so sorry about that .
Actually I wanted to generate LAMMPS data file and input file with moltemplate .
I used " oplsaa_moltemplate.py " and I made LT file and after that I used moltemplate for converting it to LAMMPS data /input files !
It worked and I have data file and input file for my molecule , with using of VMD and topoTools I can visualize it .
But when i start MD simulation , the molecule has dissociation inside of it and it is obvious that my data file has problem .
This is strange because as I said i can visulaize the molecule by topotools and VMD !
When i run the code I have also warning like " net charge is not zero " !
I have attached my LT file with this Email.
Best Regards ,
Saeed.
Fluorene.lt (3.73 KB)
data.Fluorene (4.25 KB)
Hi .
moltemplate .
then you'll have to debug it.
and VMD !
a visualization only shows the bonds and doesn't say anything about
incorrect parameters.
well, should the system be neutral or not? only you can know. there
are no charges assigned at all in your data file.
that is pointless.
Hi
I think I fixed the problem with your LT file, and posted the solution
today in a new thread. Look for a message with the subject:
"Moltemplate and OPLSAA: net charge is not zero". The problem was a
result of the atom-types you were using. Cheers.
Andrew
