Hello everybody,
I need some help.
I’m having some problems simulating my Au79 nanoparticle coated with thiols in vacuum (for now).
When minimization begins, the gold core literally explode while thiols remain almost in their initial positions.
Here are the first section of the data.file and my input.
DATA.FILE:
"LAMMPS Description
401 atoms
331 bonds
536 angles
681 dihedrals
28 impropers
5 atom types
6 bond types
11 angle types
12 dihedral types
1 improper types
-50.0 50.0 xlo xhi
-50.0 50.0 ylo yhi
-50.0 50.0 zlo zhi
Pair Coeffs
1 5.29 2.951 #Au
2 1.85 0.12 #C
3 2.0 0.02 #H
4 1.60 0.20 #O
5 2.0 0.2 #S
Bond Coeffs
1 98.6 1.09 #C-H
2 553.0 0.96 #H-O
3 45.0 2.27 #Au-S
4 222.0 1.81 #C-S
5 260.0 1.526 #C-C
6 570.0 1.229 #C-O
Angle Coeffs
1 50.0 109.50 #H-C-S
2 35.0 109.0 #C-C-H
3 35.0 133.0 #C-O-H
4 88.0 110.0 #Au-S-Au
5 35.0 109.0 #H-C-H
6 180.0 349.0 #S-Au-S
7 90.0 110.0 #Au-S-C
8 50.0 114.7 #C-C-S
9 63.0 112.4 #C-C-C
10 80.0 126.0 #O-C-O
11 70.0 117.0 #C-C-O
Dihedral Coeffs
1 0.0 0.0 0.366 0.0 #C-C-C-H
2 0.0 0.0 0.452 0.0 #H-C-C-S
3 0.0 0.0 0.16 0.0 #H-C-S-Au
4 0.0 0.0 0.318 0.0 #H-C-C-H
5 0.0 0.0 0.16 0.0 #C-C-S-Au
6 0.0 0.0 0.0 0.0 #S-Au-S-C
7 1.711 -0.5 0.633 0.0 #C-C-C-O
8 0.0 4.83 0.0 0.0 #O-C-O-H
9 0.0 0.0 0.0 0.0 #S-Au-S-Au
10 1.876 0.0 0.0 0.0 #C-C-C-S
11 0.0 4.83 0.0 0.0 #C-C-O-H
12 0.0 0.0 0.0 0.0 #H-C-C-O
Improper Coeffs
1 10.5 180.0 #O-C-O-C
Masses
1 196.966553 # Au
2 12.010700 # C
3 1.007940 # H
4 15.999400 # O
5 32.064999 # S
INPUT:
"units real
atom_style full
region nano block -25 25 -25 25 -25 25 units box
pair_style lj/cut 7.2
bond_style harmonic
angle_style harmonic
dihedral_style opls
improper_style harmonic
read_data data.alkanethiolsnp
neighbor 0.3 bin
neigh_modify delay 5
#Minimization
reset_timestep 0
thermo 1
dump np all xyz 10 alkanethiolsnp.xyz
dump_modify np element Au C H O S
min_style sd
minimize 1.0e-7 1.0e-9 10000 10000
#Equilibration
reset_timestep 0
timestep 1
fix np all nvt temp 0.01 300 0.5
thermo 10
run 10000"
Thanks for your help.
Michele
