Ok, so I am looking at this function here:
void PairCoulCut::compute(int eflag, int vflag)
int i,j,ii,jj,inum,jnum,itype,jtype;
double qtmp,xtmp,ytmp,ztmp,delx,dely,delz,ecoul,fpair;
double rsq,r2inv,rinv,forcecoul,factor_coul;
int *ilist,*jlist,*numneigh,**firstneigh;
ecoul = 0.0;
if (eflag || vflag) ev_setup(eflag,vflag);
else evflag = vflag_fdotr = 0;
double **x = atom->x;
double **f = atom->f;
double *q = atom->q;
int *type = atom->type;
int nlocal = atom->nlocal;
double *special_coul = force->special_coul;
int newton_pair = force->newton_pair;
double qqrd2e = force->qqrd2e;
inum = list->inum;
ilist = list->ilist;
numneigh = list->numneigh;
firstneigh = list->firstneigh;
// loop over neighbors of my atoms
for (ii = 0; ii < inum; ii++) {
i = ilist[ii];
qtmp = q[i];
xtmp = x[i][0];
ytmp = x[i][1];
ztmp = x[i][2];
itype = type[i];
jlist = firstneigh[i];
jnum = numneigh[i];
for (jj = 0; jj < jnum; jj++) {
j = jlist[jj];
factor_coul = special_coul[sbmask(j)];
j &= NEIGHMASK;
delx = xtmp - x[j][0];
dely = ytmp - x[j][1];
delz = ztmp - x[j][2];
rsq = delxdelx + delydely + delz*delz;
jtype = type[j];
if (rsq < cutsq[itype][jtype]) {
r2inv = 1.0/rsq;
rinv = sqrt(r2inv);
forcecoul = qqrd2e * scale[itype][jtype] * qtmp*q[j]rinv;
fpair = factor_coulforcecoul * r2inv;
f[i][0] += delxfpair;
f[i][1] += delyfpair;
f[i][2] += delzfpair;
if (newton_pair || j < nlocal) {
f[j][0] -= delxfpair;
f[j][1] -= delyfpair;
f[j][2] -= delzfpair;
if (eflag)
ecoul = factor_coul * qqrd2e * scale[itype][jtype] * qtmp*q[j]*rinv;
if (evflag) ev_tally(i,j,nlocal,newton_pair,
0.0,ecoul,fpair,delx,dely,delz);
if (vflag_fdotr) virial_fdotr_compute();
There appears to be a distance-dielectric function in pair_cut_diel.cpp and this one is from pair_coul_cut.cpp. I want to add new functions for non-polar solvation and possibly electrostatics in the future… I was looking at this reference implementation which may need to be modified:
http://www.ncbi.nlm.nih.gov/pubmed/17918282
My specific question is that if I only update the energy and not the forces, would this work with a hybrid MD/MC that uses MD to propose moves and MC to accept? I was going to start by just computing the energies and doing MC and then put in the full forces later. From a theoretical perspective the answer is yes (since the MD moves fulfill detailed balance), but I am asking from the perspective of LAMMPS. So I would just not update the forces yet and use zeros, but add to either the vdw or coulomb energies and use the GCMC in LAMMPS along with fix_nvt.
Luke
