Hello lammps users,
I’m trying to compile lammps11-Aug17. When I do “make mpi” in /src, I got the error:
fft3d.o: In function fft_3d': /home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:117: undefined reference to
fftw_execute_dft’
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/…/fft3d.cpp:156: undefined reference to fftw_execute_dft' /home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:195: undefined reference to
fftw_execute_dft’
fft3d.o: In function fft_3d_destroy_plan': /home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:676: undefined reference to
fftw_destroy_plan’
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/…/fft3d.cpp:677: undefined reference to fftw_destroy_plan' /home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:678: undefined reference to
fftw_destroy_plan’
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/…/fft3d.cpp:679: undefined reference to fftw_destroy_plan' /home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:680: undefined reference to
fftw_destroy_plan’
fft3d.o:/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/…/fft3d.cpp:681: more undefined references to fftw_destroy_plan' follow fft3d.o: In function
fft_3d_create_plan’:
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/…/fft3d.cpp:570: undefined reference to fftw_plan_many_dft' /home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:575: undefined reference to
fftw_plan_many_dft’
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/…/fft3d.cpp:580: undefined reference to fftw_plan_many_dft' /home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:585: undefined reference to
fftw_plan_many_dft’
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/…/fft3d.cpp:590: undefined reference to fftw_plan_many_dft' fft3d.o:/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:595: more undefined references to
fftw_plan_many_dft’ follow
fft3d.o: In function fft_1d_only': /home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:828: undefined reference to
fftw_execute_dft’
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/…/fft3d.cpp:833: undefined reference to fftw_execute_dft' /home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:838: undefined reference to
fftw_execute_dft’
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/…/fft3d.cpp:828: undefined reference to fftw_execute_dft' /home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:833: undefined reference to
fftw_execute_dft’
fft3d.o:/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/…/fft3d.cpp:838: more undefined references to fftw_execute_dft' follow collect2: ld returned 1 exit status make[1]: *** [../lmp_mpi] Error 1 make[1]: Leaving directory
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi’
make: *** [mpi] Error 2
The version of my software is listed as below:
fftw-3.3.6-p12
mpich-3.0.1
lammps-11Aug17
Could you please help me fix this error?
Many thanks,
Tingyu
Hello lammps users,
I'm trying to compile lammps11-Aug17. When I do "make mpi" in /src, I got
the error:
fft3d.o: In function `fft_3d':
undefined reference to `fftw_execute_dft'
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:156:
fft3d.o: In function `fft_3d_destroy_plan':
undefined reference to `fftw_destroy_plan'
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:677:
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:679:
fft3d.o:/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:681:
more undefined references to `fftw_destroy_plan' follow
fft3d.o: In function `fft_3d_create_plan':
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:570:
undefined reference to `fftw_plan_many_dft'
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:580:
/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:590:
more undefined references to `fftw_plan_many_dft' follow
fft3d.o: In function `fft_1d_only':
fft3d.o:/home/heat/lammps11-Aug17/lammps-11Aug17/src/Obj_mpi/../fft3d.cpp:838:
more undefined references to `fftw_execute_dft' follow
make[1]: Leaving directory `/home/heat/lammps11-Aug17/
lammps-11Aug17/src/Obj_mpi'
fftw-3.3.6-p12
mpich-3.0.1
lammps-11Aug17
http://lammps.sandia.gov/doc/Section_start.html#step-6
start by compiling LAMMPS *without* FFTW support (which is how
Makefile.mpi ships by default).
the performance differences of LAMMPS due to the choice of FFT are quite
small and are often irrelevant unless you run on extremely large machines
and specific inputs.
