Dear Julian,
I am trying to perform a Mott-Littelton calculation using “vacancy” and “interstitial” commands.
I have completely got a result of such commands for the direct substitution mechanism:
2A = B + vacancy.
And it works by this input:
centre 0.62729 0.417555 0.758595
size 10 20
vacancy 0.62823 0.33406 0.75931
vacancy 0.62635 0.50105 0.75788
interstitial B 0.62823 0.33406 0.75931
But if I want to use it in reverse mechanism, such as
B + vacancy = 2A, by input with the same logic:
centre 0.5625 0.20793 0.75
size 10 20
vacancy 0.5 0.25 0.75
#vacancy 0.625 0.16586 0.75
interstitial A 0.625 0.16586 0.75
interstitial A 0.5 0.25 0.75
(note: here I wrote a #vacancy for your undrestanding the position of atom, wich is absent in my new supercell. I mean, this atom
#vacancy 0.625 0.16586 0.75 is a real vacancy in supercell and I want to add it using “interstitial” command),
GULP don’t see the atom on “B” position.
GULP calculate the defect, but the Total number on defect in not zero. It is equal to charge of atom “B”.
I estimated size of radiuses in two regions and I think it is enough.
Are there any problems with syntax and the logic of using “vacancy” and “interstitial” commands?
If no, thank you so much in advance, I’ll try to found a problem with my supercell.
