moving and rotation in fixe command!
I want to make a tool rotate about the z axis and move in x direction. But the tool is just move in x direction and fluctuate about the z axis. Can anyone solve it for me? thanks!
my program:
Friction stir welding of copper C11000
clear
boundary p s p
atom_style atomic
Create geometry
lattice fcc 3.615
region box block 0 63 0 16 0 20
create_box 1 box
mass 1 63.54
atom regions
region ma cone z 8 8 4 6 2.7 5.7
create atoms
create_atoms 1 region ma
EAM potentials
pair_style eam
pair_coeff 1 1 Cu_u3.eam
define groups
group tool region ma
initial velocities
velocity tool create 300 482748 mom yes rot yes
computes
compute eng all pe/atom
compute eatoms all reduce sum c_eng
fixes
fix 1 tool rigid single
Run
timestep 0.005
thermo 100
thermo_style custom step pe pxx pyy pzz c_eatoms
dump 1 all xyz 20 dump.xyz
variable V equal 8.0
variable y equal vdisplace(0.0,$V)
fix 2 tool move rotate 8.0 8.0 2.7 0.0 0.0 1.0 1
fix 3 tool move variable NULL v_y NULL NULL v_V NULL
run 1600
I don’t think you can use fix move on the same set of atoms
twice, e.g. to get rotation and translation. You’d have to write
a fancier variable that did both motions in one fix move command.
This is b/c the way fix move works it puts each atom in the position
that fix move command specifies. So the 2nd one will simply
override the first.
You might want to try using fix move rotate to rotate your group tool,
and then use velocity set to move the group in the x direction.
Ray
Dear Sir!
I still haven’t solved for making a tool rotate about the z axis and move in y direction. Otherwise, I can make a tool rotate and move about the y direction. The code as the following:
clear
boundary p s p
atom_style atomic
Create geometry
lattice fcc 3.615
create_box 1 box
mass 1 63.54
atom regions
create atoms
EAM potentials
pair_style eam
define groups
initial velocities
computes
fixes
Run
timestep 0.005
thermo 100
variable dy equal vdisplace(0.0,$V)
fix 3 tool move rotate 8.0 8.0 2.7 0.0 1.0 0.0 1
fix 4 tool move variable NULL v_dy NULL NULL v_V NULL
run 1600
Please you help me to solve for making a tool rotate about the z direction and move in y direction!
Thanks!
Vào ngày 12:55 Thứ Ba, 5 tháng 11 2013, long tranngocbaolong <tranngocbaolong822008@…4656…25…> đã viết:
my program:
clear
boundary p s p
atom_style atomic
Create geometry
lattice fcc 3.615
create_box 1 box
mass 1 63.54
atom regions
create atoms
EAM potentials
pair_style eam
define groups
initial velocities
computes
fixes
Run
timestep 0.005
thermo 100
run 1600
I think I answered this Q before. You cannot apply fix move
twice to the same atoms.
