Dear LAMMPS users,
When I use 12 cores to run a job, I found there is no parallelization, that is, all cores was doing same thing, all lines in screen output has 12 copies.
And the processor grid was:
My job script is like below:
#!/bin/bash -l
#SBATCH --job-name=test
#SBATCH --time=90000200:00:0
#SBATCH --nodes=1
#SBATCH --ntasks-per-node=12
mpirun -np 12 lmp_7Aug19 -echo screen -in in.cool > screen.log
My test lammps inputs and job script was copies of that I used before (before they can run normally), thus I believe there is no problem in my input.
And other users tested lammps on same machine. So the machine has no problem. They used lammps they compiled by themselves.
But I test 3 versions of lammpls I compiled before and I found same issue. All these lammps can run normally before. And recently, it seems I didn’t recompile them.
Could you please give me some suggestions to fix this issue? Thanks in advance!
Zhao
