I want to simulate germanium nanowire with point defect. Defects that I considered are 1% up to 8%. For low percentage, the simulation works fine, But in 8% defect on step 1200000 crashes. Every time that I run simulation, it happens again but on different step such as 1000000 or 1500000! The massage that will be shown is: mpirun noticed that the process rank 1 with PID 1981 on node …
This is a piece of my code.
variable P equal 0.08
variable R equal 20
variable T equal 300
variable L equal 200
variable dt equal 60
variable Thot equal T+{dt}/2.0
variable Tcold equal T-{dt}/2.0
log log.lammpsT$TR$R-P$P
echo both
atom_style atomic
boundary s s s
############################## ########## BOX
variable z1 equal 0
variable z2 equal L+20
region box block -100 100 -100 100 {z1} ${z2} units box
create_box 1 box
region nw cylinder z 0 0 $R EDGE EDGE units box
lattice diamond 5.658
create_atoms 1 region nw
############################## ########## MASS
mass 1 72.64
############################## ########## VELOCITY
velocity all create $T 87287 mom yes rot yes dist uniform
delete_atoms porosity box $P 482793
############################## ########## POTENTIAL
pair_style tersoff
pair_coeff * * SiCGe.tersoff Ge
neighbor 2 bin
neigh_modify every 50 delay 0
############################## ########## REGIONS
region fl block INF INF INF INF INF 5 units box
group fl region fl
region 0 block INF INF INF INF 10 15 units box
region hot block INF INF INF INF 15 30 units box
group hot region hot
region 1 block INF INF INF INF 30 40 units box
region 2 block INF INF INF INF 40 50 units box
region 3 block INF INF INF INF 50 60 units box
region 4 block INF INF INF INF 60 70 units box
region 5 block INF INF INF INF 70 80 units box
region 6 block INF INF INF INF 80 90 units box
region 7 block INF INF INF INF 90 100 units box
region 8 block INF INF INF INF 100 110 units box
region 9 block INF INF INF INF 110 120 units box
region 10 block INF INF INF INF 120 130 units box
region 11 block INF INF INF INF 130 140 units box
region 12 block INF INF INF INF 140 150 units box
region 13 block INF INF INF INF 150 160 units box
region 14 block INF INF INF INF 160 170 units box
region cold block INF INF INF INF 170 185 units box
group cold region cold
region 15 block INF INF INF INF 185 190 units box
region fr block INF INF INF INF 190 INF units box
group fr region fr
group 1 region 1
group 2 region 2
group 3 region 3
group 4 region 4
group 5 region 5
group 6 region 6
group 7 region 7
group 8 region 8
group 9 region 9
group 10 region 10
group 11 region 11
group 12 region 12
group 13 region 13
group 14 region 14
group middle subtract all fl fr hot cold
############################## ########## HOT & COLD
fix 1 hot nvt temp {Thot} {Thot} 0.1
fix 2 cold nvt temp {Tcold} {Tcold} 0.1
fix 5 middle nve
############################## ########## SETFORCE
fix 3 fl setforce 0 0 0
fix 4 fr setforce 0 0 0
velocity fl set 0 0 0 units box
velocity fr set 0 0 0 units box
thermo 1000
thermo_style custom step cpu
timestep 0.001
run 2000000
Thanks a lot
Abdollahi
