I want to simulate germanium nanowire with point defect. Defects that I considered are 1% up to 8%. For low percentage, the simulation works fine, But in 8% defect on step 1200000 crashes. Every time that I run simulation, it happens again but on different step such as 1000000 or 1500000! The massage that will be shown is: mpirun noticed that the process rank 1 with PID 1981 on node …
This is a piece of my code.
variable P equal 0.08
variable R equal 20
variable T equal 300
variable L equal 200
variable dt equal 60
variable Thot equal T+{dt}/2.0
variable Tcold equal T-{dt}/2.0
log log.lammpsT$TR$R-P$P
echo both
atom_style atomic
boundary s s s
######################################## BOX
variable z1 equal 0
variable z2 equal L+20<br>region box block -100 100 -100 100 {z1} ${z2} units box
create_box 1 box
region nw cylinder z 0 0 $R EDGE EDGE units box
lattice diamond 5.658
create_atoms 1 region nw
######################################## MASS
mass 1 72.64
######################################## VELOCITY
velocity all create $T 87287 mom yes rot yes dist uniform
delete_atoms porosity box P 482793<br><br>######################################## POTENTIAL<br>pair_style tersoff<br>pair_coeff * * SiCGe.tersoff Ge<br><br>neighbor 2 bin<br>neigh_modify every 50 delay 0<br>######################################## REGIONS<br>region fl block INF INF INF INF INF 5 units box<br>group fl region fl<br><br>region 0 block INF INF INF INF 10 15 units box<br><br>region hot block INF INF INF INF 15 30 units box<br>group hot region hot<br>region 1 block INF INF INF INF 30 40 units box<br>region 2 block INF INF INF INF 40 50 units box<br>region 3 block INF INF INF INF 50 60 units box<br>region 4 block INF INF INF INF 60 70 units box<br>region 5 block INF INF INF INF 70 80 units box<br>region 6 block INF INF INF INF 80 90 units box<br>region 7 block INF INF INF INF 90 100 units box<br>region 8 block INF INF INF INF 100 110 units box<br>region 9 block INF INF INF INF 110 120 units box<br>region 10 block INF INF INF INF 120 130 units box<br>region 11 block INF INF INF INF 130 140 units box<br>region 12 block INF INF INF INF 140 150 units box<br>region 13 block INF INF INF INF 150 160 units box<br>region 14 block INF INF INF INF 160 170 units box<br>region cold block INF INF INF INF 170 185 units box<br>group cold region cold<br><br>region 15 block INF INF INF INF 185 190 units box<br><br>region fr block INF INF INF INF 190 INF units box<br>group fr region fr<br><br>group 1 region 1<br>group 2 region 2<br>group 3 region 3<br>group 4 region 4<br>group 5 region 5<br>group 6 region 6<br>group 7 region 7<br>group 8 region 8<br>group 9 region 9<br>group 10 region 10<br>group 11 region 11<br>group 12 region 12<br>group 13 region 13<br>group 14 region 14<br>group middle subtract all fl fr hot cold<br><br>######################################## HOT & COLD<br>fix 1 hot nvt temp {Thot} {Thot} 0.1<br>fix 2 cold nvt temp {Tcold} ${Tcold} 0.1
fix 5 middle nve
######################################## SETFORCE
fix 3 fl setforce 0 0 0
fix 4 fr setforce 0 0 0
velocity fl set 0 0 0 units box
velocity fr set 0 0 0 units box
compute hot hot temp
compute 1 1 temp
compute 2 2 temp
compute 3 3 temp
compute 4 4 temp
compute 5 5 temp
compute 6 6 temp
compute 7 7 temp
compute 8 8 temp
compute 9 9 temp
compute 10 10 temp
compute 11 11 temp
compute 12 12 temp
compute 13 13 temp
compute 14 14 temp
compute cold cold temp
compute ke middle ke/atom
compute pe middle pe/atom
compute stress middle stress/atom NULL virial
compute J middle heat/flux ke pe stress
variable Jz equal c_J[3]/(3.14*$R*R*140)<br>########################################<br>thermo 1000<br>thermo_style custom step cpu<br>fix ave all ave/time 1 500000 500000 v_Jz c_hot c_1 c_2 c_3 c_4 c_5 c_6 c_7 c_8 c_9 c_10 &<br>c_11 c_12 c_13 c_14 c_cold file ave-r{R}-T$T-dt${dt}-P$P.txt
dump 1 all atom 500000 dump-r${R}-T$T-dt${dt}-P$P.lammpstrj
timestep 0.001
run 2000000
Thanks a lot
Abdollahi
