Hi, I am not sure why, but the MPRester get_entries_in_chemsys seems quite unstable.
The specific problem is when I do " qe.get_entries_in_chemsys([element lists…]) "
Until yesterday, it has always worked fine. However, now I do not receive the queried data and keep getting the following error.
File “/home/kyujung/miniconda3/lib/python3.7/site-packages/pymatgen/ext/matproj.py”, line 168, in _make_request
raise MPRestError(data[“error”])
pymatgen.ext.matproj.MPRestError: mongodb08.nersc.gov:27017: [Errno 113] No route to host
- I have tried multiple API keys, but all same problem.
- I suspected there may be a connection problem, but get_entries_by_mpid works fine, so I think connection would not be an issue.
- I have tried “get_entries” instead of “get_entries_in_chemsys” with the same elements and it does work.
- I have tried manually querying multiple entries by “get_entries_by_mpid” and the first query of a single entry works fine, but the error consistently pops up from the query of the second entry.
Is there something new that I have changed regarding “get_entries_by_chemsys”? Or perhaps querying multiple entries currently is not stable for some reason?
Thank you!
KyuJung
