Hi!
I am encountering a problem when trying to import MPRester: basically the code runs for minutes and is not able to finalize the code chunks. I have been trying the following import methods:
from pymatgen.ext.matproj import MPRester
(Legacy API) -
from pymatgen import MPRester
(older version) -
from mp_api import MPRester
(new API suggested at [Materials Project - API], but the python commandimport mp_api
seems not to work)
The simple statement from pytmatgen import ext
works, but MPRester appears not to be available.
I am running on miniconda3, Python 3.10.2: any ideas about what may be happening ?
EDIT: I am working in a virtual conda environment where I only condaforged pymatgen
and pip-installed mp_api
EDIT2: same happens in environments where I only use pip install for the packages
EDIT3: whatever I do, I end up in the same problem. Ctrl+c always returns the same traceback:
File "c:\Users\(username)\Documents\Python Scripts\Materials Project\MP_api.py", line 21, in <module>
import pymatgen.core as mg
File "C:\Users\(username)\miniconda3\envs\pymatgen\lib\site-packages\pymatgen\core\__init__.py", line 54, in <module>
SETTINGS = _load_pmg_settings()
File "C:\Users\(username)\miniconda3\envs\pymatgen\lib\site-packages\pymatgen\core\__init__.py", line 43, in _load_pmg_settings
d_yml = yaml.load(f)
File "C:\Users\(username)\miniconda3\envs\pymatgen\lib\site-packages\ruamel\yaml\main.py", line 434, in load
return constructor.get_single_data()
File "C:\Users\(username)\miniconda3\envs\pymatgen\lib\site-packages\ruamel\yaml\constructor.py", line 119, in get_single_data
node = self.composer.get_single_node()
File "C:\Users\(username)\miniconda3\envs\pymatgen\lib\site-packages\ruamel\yaml\composer.py", line 76, in get_single_node
document = self.compose_document()
File "C:\Users\(username)\miniconda3\envs\pymatgen\lib\site-packages\ruamel\yaml\composer.py", line 99, in compose_document
node = self.compose_node(None, None)
File "C:\Users\(username)\miniconda3\envs\pymatgen\lib\site-packages\ruamel\yaml\composer.py", line 143, in compose_node
node = self.compose_mapping_node(anchor)
File "C:\Users\(username)\miniconda3\envs\pymatgen\lib\site-packages\ruamel\yaml\composer.py", line 223, in compose_mapping_node
item_value = self.compose_node(node, item_key)
it appears to me that the import command runs in a loop of some sort (the last two lines actually repeat many times), but I can’t wrap my mind around it.
