msi2lmp error
Dear LAMMPS user:
I am using the msi2lmp to generate data file. However, when I try the test examples within the msi2lmp package, it outputs error as below. I didn’t met such problem with an old version (in year 2012), anyone can help to advise what going wrong?
Here is the command I input & the output error message.
Command:
msi2lmp.exe benzene-class2a -class II -frc pcff
output:
Running msi2lmp v3.9.7 / 24 Oct 2015
Forcefield: Class II
Forcefield file name: …/frc_files/pcff.frc
Output is recentered around geometrical center
Output contains style flag hints
System translated by: 0 0 0
Reading car file: benzene-class2a.car
Reading mdf file: benzene-class2a.mdf
Building internal coordinate lists
Reading forcefield file
Get force field parameters for this system
Unable to find mass for h1
Best Regards!
Dai Ling
Dear LAMMPS user:
the "class2a" files are typed for use with compass, not pcff. pcff
uses different type names. if you try the same command with a
"class2b" test file, it should work. see the "runtests.sh" file in the
test folder.
